4th Gen. Firebird knight rider dashboard
- KARR 2000
I remember seeing it once but I don't remember where.
I googled to find it but I was not successful.
Does anybody remember the website it was on?
Thanks
Thanks
So...... I have no idea what to write here.
- TurbomanKnight
i dont have the 4th generation kitt dash, but i do have a pretty good rendition of what kitt could look like as an LT1 fbody... the first pic is from their site, the last pic is my real car.... wheels and all
- spyhunter
Definitely, that nose is not right! The scanner must be directly under the hood line, and it probably should be a bit bigger than the original KITT's, since the whole 4th Gen car is a bit bigger or bulgier anyway...
The scanner size on this nose looks to be even smaller than the original KITT, that's no good... I can't believe their perception was that far off!
SH
SH
- knightrider2004
- Army_F_Body
- spyhunter
I hope Don makes it more proportionately acceptable!
Check out this KITT that was recently owned by Cesar Gamino (crashed last year):
You can see how much better the scanner looks at the hood line even though it should be a bigger scanner to fill out the indentations in the nose. Someone needs to create a larger scanner for this car!
This is the banshee nose by Rob Louisell, only Cesar did a custom job with the scanner.
I think a stock T/A nose with a large scanner would look great too!
SH
SH
- Army_F_Body
- knightdriver
I am not usre if you have ever looked under the hood of a 4th Gen
or not but putting a csanner in the same location as a 3rd Gen isn't
that easy. This si why Don moved his forward as well as in my design.
There is a lot interfering with putting one in that spot without a ton of
modifications to the hood latch area.
Also, Don told me that the scanner in the newer car is the same one he
uses in the 3rd Generation kitts. It just looks smaller in the bigger nose.
I understand the logistics behind moving the scanner down, but I still don't think it looks quite right. To me, it kind of looks like it's just floating in the middle of the nose. I think the 4th generation Trans Ams would be better off with an entirely different customized nose like they did in the series.
I'm sure when the '98-'02 custom noses are made that they will look much better. I think the problem lies in Pontiac's design, not Don's. The nose for the '93-'97 Firebirds is too smooth and plain for any type of scanner to look like it would naturally fit there. I think K.I.T.T.'s nose and scanner accomodated the Trans Am beautifully, especially in the 4th season where the sharper lines matched the car most accurately. The '98-'02 Firebirds obviously have more design on them.
The Knight 4000's nose suffered from this same problem, but they rounded out the nose so that the scanner would look more natural.
- knightdriver
- ReddawgKnight
- pbryant_knight
This entire car looks AWESOME as a new KITT and SHOULD be used in the new film. Its a new car, its still black, it still has the essential parts to the dash and still looks updated. NICE!!!!!!!knightdriver wrote:This is the nose we are currently working on. It may vary a bit from this
picture but the idea is similar. Our scanner is forward a bit, but only like 2
inches. Not quite as far as Don did his. This keeps it close to the hood but
gets us past the problem points of the real car!
Peter
One Man Can Make A Replica
Re:
Hey,MSKEN,weren't these photos supposed to be teasers for your knight rider fan based game?Great photoshop work by the way.knightdriver wrote:This is the nose we are currently working on. It may vary a bit from this
