Kitt at 500 MPH!!!!!
Knight-Armen
Post by Knight-Armen » Mon May 15, 2006 5:50 am
Do you guy's remember when Michael made Kitt a ramjet (Goliath)? It's extremely hard for me to believe that a car can travel 500 mph (800 km/h)! I mean, the car weigh's about 2 ton's and it was travelling in the desert (imagine the freeway)! Even if this would be possible, the chassi would not be able to hold onto the car!
Michael: Kitt what matters to me is who you are not what you look like. Sure we don't have the car so we can't turbo boost so we can't go over 200 miles an hour but it was all icing on the cake anyway
whet
Post by whet » Mon May 15, 2006 5:54 am
I think kitt's speed readout could have malfunctioned so that maybe could explain it showing 500 MPH.
I do wonder however if we ever get this movie that keeps getting talked about what Kitt's top speed would be?
Major Ursa
Post by Major Ursa » Mon May 15, 2006 7:52 am
I did remember that episode where Micheal had ro jerryrig the drive systems to make aramjet engine so KITT could escape to the safety of the Serivec truck. before Goliath could come back to do more damage.
"Oh I just went to any Pontiac dealer and asked for the Trans Am with the James Bond option package." - Micro Knutt, Knutt Rider(A Mad Magazine parody of Knight Rider)
Knight2000
Post by Knight2000 » Mon May 15, 2006 8:43 am
I think it was more that KITT wasn't designed to run on a ramjet and that the speedometer probably wasn't calibrated for ramjets, which meant that it gave false readings.
But then again, many of KITT's systems were malfunctioning too so that could have given a false reading.
Knight-Armen
Post by Knight-Armen » Mon May 15, 2006 1:31 pm
But Kitt was confirming at the same time that their speed was about 500 mph!? I think the lines went like this:
Kitt: Michael, our speed is about 500 miles per hour, the odds is if we are going to survive!
Michael: I hear ya, but the ramjet doesn't seem to be able to control! Hang on buddy!
Kitt: But, where are we going?
Michael: Out of the desert...
KFCreator
Post by KFCreator » Mon May 15, 2006 5:53 pm
No, KITT did not confirm that they were going anywhere near 500 MPH. Also, I don't know where in that scene you saw the speedometer at 500 MPH because I just watched it and the highest I saw it get to was about 212 MPH. The line from the scene in that episode is:
KITT: Michael, at our prsent speed of 310 MPH, the odds of our survival are...(shows screen of KITT's circuitry)...my odds calculator just malfunctioned.
Hope this helps clear this up!
Akaihiryuu
Post by Akaihiryuu » Mon May 15, 2006 8:10 pm
I didn't really like that part of the episode, honestly. First off, why was Michael looking under the hood for turbine blades? The turbine blades are *inside* the engine, near the back. And why would broken turbine blades make the engine a ramjet? The compressor is at the front...though it is usually driven by the turbine (except at startup where it has to be driven by an external motor). Even if you DID take the compressor out, you still have to have enough airflow into the engine to make the ramjet work. Ramjets have to be at at a *minimum* of half the speed of sound (at ground level about 750 mph/2 or 375 mph) to produce any thrust. Quoted from Wikipedia: "Ramjets generally give little or no thrust below about half the speed of sound, and they are inefficient (less than 600 seconds due to low compression ratios) until the airspeed exceeds 1000 km/h (600 mph). Even above the minimum speed a wide flight envelope (range of flight conditions), such as low to high speeds and low to high altitudes, can force significant design compromises, and they tend to work best optimised for one designed speed and altitude (point designs). However, ramjets generally outperform gas turbine based jet engine designs at supersonic speeds (mach 2-4)." Sadly, I thought that whole part about "rigging a ramjet" was ridiculous, meaningless technobabble at best. It's hard to suspend disbelief when they do ridiculous things like that. Goliath was great otherwise though...probably in the top 5 of the series.
All the info you could want on ramjets: http://en.wikipedia.org/wiki/Ramjet
Knight-Armen
Post by Knight-Armen » Tue May 16, 2006 9:37 am
I didn't say that I "saw" the speedometer at 500 mph, did I!? My assumtion was that Kitt said that their speed was about 500 mph. Now, whether that's true or not, I can't tell, because it was a long time ago, since I watched that particular episode...
JKDY
Post by JKDY » Tue May 16, 2006 10:13 am
KFCreator has got it exactly right.
Rossy
Post by Rossy » Tue May 16, 2006 6:43 pm
i think he only did it to get out of the desert then got a lift back to flag
James_kr
Post by James_kr » Wed May 17, 2006 3:17 am
theres almost no reason for SPM if KITT can travel at that speed but I think SPM is faster.
Also on the S3 dash the speedometer has lights up to 300 + in S1/S2 it had 200 +
K.I.T.T: "Dog go away"
Starship
Post by Starship » Wed May 17, 2006 4:11 am
Ahhh! Does that bring back memories! I remember that episode when I first saw it way back when I was in college. The whole ramjet scene was one that stuck with me -- not realizing how improbable it would be to be able to "rig up a ramjet." I even remember KITT saying something like "A ramjet?! My exhaust system is not designed for the kind of heat a ramjet would produce, not to mention that navigation would be practically impossible!" I was wondering if the car was going to fly. But, yes, as I recall, KITT only spoke of a speed of 310 mph, though I presume he was still accelerating at that point.
I try to put a little KITT in any car I own!
James_kr
Post by James_kr » Thu May 18, 2006 2:29 am
how could a ramjet work when all the turbine blades are shot
knight_rider_turkey
Post by knight_rider_turkey » Thu May 18, 2006 2:36 pm
Wowww that is impossible :)
Jay_n1
Post by Jay_n1 » Thu May 18, 2006 4:23 pm
No Kitt didn't really confirmed that they were going 500 MPH, I think the scene went like this:
(Michael gets Kitt up and the ramjet gets Kitt going.)
Michael: "It's working!"
Kitt: "Yes but for how long, the odds of serviving at these speeds are a gamble a best."
Michael: hear ya, but the ramjet doesn't seem to be able to control! Hang on buddy!
James_kr
Post by James_kr » Thu May 18, 2006 5:48 pm
he said 310mph theres no 500mph involved i think he had a correct reading
Knight-Armen
Post by Knight-Armen » Fri May 19, 2006 3:16 pm
I think I got it now, no need for any further explanation...
Skav
Post by Skav » Fri May 19, 2006 7:18 pm
What bugs me about this scene is how michael was able to control kitt once he were back onto the main road?
