1) The hood cowl was flipped, meaning the image of KITT was flipped as well.
2) In the top right corner of the package is a text that contains the opening words to Knight Rider - "Knight Rider a Shadowy Flight..." The lines of this phrase was mixed up, placed in the wrong order.
Well I have some good news and bad news about it. We contacted Universal about it, and they said they would see what could be done. They were true to their word and have corrected the two issues, but have added a new one.
Sith found this image on Amazon today:
It may be obvious at first glance, it may not. Look again and notice that the glow for the scanner is bellow the actual scanner itself. I again contacted Universal and received this response:
It looks as if the packaging for the set has already been approved and gone to press. It is possible that the image on Amazon and the info from the Universal rep will be wrong, but it isn't likely.Glad you like the new image. We try to fix what we can. Luckily we had time in this case. It's too late to go back and address the scanner thing. I can't believe the detail you notice!
While this is disappointing that such an error would be made, in the place of two errors, I hope that we can all learn to accept it and understand that it's not on the outside that counts, but what is on the inside.
****UPDATE****
http://bb.knightrideronline.com/viewtop ... 5605#55605
