GTA3 and kitt
GTA3 and kitt
Has anyone seen kitt or a black 1982 trans am in the game.If so does it look accurate?If anyone can please post some pics here.
Privateer5000
Found Kitt for GTA 3
HI folks
Here the Link where you can find two Versions off Kitt for GTA 3.
http://gta3.gamigo.de
You just have to klick on Cars in the File Section on the left side and then on "Sonstige". You can find them on Page 4 and 6.
Greets from Germany
Privateer5000
[SuperMod German Knight-Rider-Board]
http://www.Knight-Rider-Board.de
Greets from Germany
Privateer5000
Privateer5000
Privateer5000
I installed the first Version of the Car (not the convertible). i have to say sorry because i did not post the translation, but i had a lot to do the last days and simply forgot it. Translation is following today, i promise.
Greets Privateer5000
P.S Sorry for my bad english and all errors i made in my Post
Privateer5000
Installation Instructions
Installation Instruction for KITT v2.0 (not the convertible)
First you have to download the IMG Tool: http://www.gta3.gamigo.de/?page=showfil ... ortby=date
1: Modell Installation:
- Open the file “gta3.img” in the models directory with the IMG Tool
- Search the entry “borgnine.dff” using F3
- Rename to borgningold.dff
- Import “borgning.dff” from the Zip-File (Strg + A)
2: Texture Installation:
- open “txd.img” in the models directory with the IMG Tool
- search “borgning.txd”
- rename to “borgnineold.txd”
- import “borgnine.txd” from Zip-File
3: Handling:
- backup “handling.cfg” in the data directory
- open “handling.cfg” with notepad and change the entry of the Borgnine as following:
BORGNINE 1400.0 2.3 4.5 1.6 0.0 -0.01 -0.5 70 2.0 0.84 0.53 5 300 35.0 R P 13.1 0.52 0 30.0 1.8 0.13 0.2 0 100000 0.25 -0.18 0.5 A083 1 1
4: Install Tyres:
- backup “misc.txd” in the models directory
- copy “misc.txd” from Zip-File to models directory
- backup “default.ide” in data directory
- open “default.ide” with notepad and change the Borgnine Entry : 148, borgnine, borgnine, car, BORGNINE, BORGNIN, ignore, 1, 7, 0, 164, 0.72
5: Install Scanner Sound:
- Copy Scanner.mp3 from Zip-File into the mp3 directory
- It have to be the only mp3 File in the directory
- Choose “LCG Radio” in the Game
That’s it. I think you can adept the Instruction for the second Kitt Model
If you haven’t unlock the Borgnine Taxi you can try to replace another Car but then it could happen that there are driving a lot of KITT through Liberty City, KARR and the whole Family, lol
Have Fun driving trough Liberty City with KITT
3: Handling:
4: Install Tyres:
- SWerni
Ok... try to use this link
http://gta3.gamigo.de/downloads/upload/imgtool_1.3.zip
should be working
Sandra
should be working
Sandra
- Knight Industry
Where in the game can I find the Borgnine Taxi? I've just completed the game, but never saw this car.
I now replaced the Patriot (Hummer) with KITT and it looks great! Especially the interior! Real nice job. Only too bad that the car isn't indestructable. And I was hitting space bar to Turbo Boost (like in Knight Rider game) but it didnt work
Just some questions: is it possible to get that real KITT engine sound? And when I get into KITT, it still says 'Patriot' at the bottom of the screen. Can this be altered?
I'm having a problem installing kitt.I used the program and followed all the steps but on the second step it said to :
and the img program can't find that file for some reason.Is there a way to replace another car with kitt?I wouldn't mind changng the taxi cabs for him and seeing the fleet cause the more kitts on the road the better.Kinda like what karr always said,"I am the car of the future!" so kitts wouldn't be that surprising in gta 3 even though its 1982 there.
- NightmareDemon
About Changing Patriot To KITT, or Knight Rider
Ok, there is a program from the GTA3.net site you'll have to get, let me scroll thru my files and find it............
ok, here it is, it's GXTEdit. In this program you'll have to change the text in the game. Which i've been able to change everything. I changed the Patriot to Hummer H1, and i installed a Viper GTSR over the Infernus which I renamed Viper GTSR, you get the picture. You'll have to change to main Patriot text files. I'll tell you how right here.
first you'll have to open the program. then open the file, to find it go to your GTA3/TEXT folder. then open american.gxt. Then click on the POS tab to make everything in order. On lines 208 and 2173 rename the Patriot to whatever you wanna call it. THen save it, then open the english.gxt file, i'm not sure which one the game reads, so i just edit both at once. so i don't have to fool around with it later on. On lines 208 and 1872 change those to whatever but make sure they are the same as what's in the american.gxt file. In both files, what you want to change will be what is under the String category. Then save it, and you're done.
Whew, easier doing it, than typing it all out. Hope this helps, any problems lemme know.
