Why couldn`t they just reprogramme KARR?
- KARR 2000
So do you know the answer?
So...... I have no idea what to write here.
Re: Why couldn`t they just reprogramme KARR?
yes I know it!KARR 2000 wrote:So do you know the answer?
Because it was written in the script
That´s a very good question, KARR 2000. It´s hard to say why they couldn´t reprogram K.A.R.R. I think it can be because of the ancient computers (according to 21st century´s standards) they might have had in the F.L.A.G that you can add the programs in the unit but you can´t change the programs you previously made. I don´t know if the so called ancient computers had have that kind of problem in the real life but I suppose that might have been possible.
KITT was often reprogrammed, so it should be also possible with KARR-Jake wrote:That´s a very good question, KARR 2000. It´s hard to say why they couldn´t reprogram K.A.R.R. I think it can be because of the ancient computers (according to 21st century´s standards) they might have had in the F.L.A.G that you can add the programs in the unit but you can´t change the programs you previously made. I don´t know if the so called ancient computers had have that kind of problem in the real life but I suppose that might have been possible.
- neps
We've actually just had this converation recently (slaps broken record)
The general concenus was that KARR was a prototype, and it is quite possible that more than just his programming was wrong. It's much better for them to start from scratch, to learn from their mistakes in more areas than KARRs program.
Perhaps reading this thread will help:
http://bb.knightrideronline.com/viewtopic.php?t=2677
well don't take things in KR too serious. There are lot of things which do not make sence.
for eg.: when KARR whent wrong, why did they built a brand new car? instead of replace KARR's CPU with KITT's.
Or this is a bettter "mistake"
They built KITT into Michaels former original Pontica 82 TransAm. Why is it possible that KARR, who was built before KITT looks exactly the same?
Well there are lot's of questions in this serie. but if you care too match on them, it is possible that you loose your interesset in Knight Rider.
Good point, Dome! My thought was that can the programs already set in the K.I.T.T or K.A.R.R be changed. However, I had noticed that Bonnie or April had reprogrammed K.I.T.T but my question was that did they set some new program to K.I.T.T to replace the previous one or could they change the program that´s already there? I don´t know. I hope this following example will make my thoughts more understandable. Let´s say our example is the Surveillance Mode. As we know, Bonnie or other technician had set that program in the first place into K.I.T.T´s systems. Soon they develop the improved version of the Surveillance Mode. According to my theory, they remove the original Surveillance Mode program and replace it with the updated version. So in this case I just explained, according to my logic, they didn´t change the original program (didn´t reprogram). They just replaced the program with new one. I think the concept of reprogramming means that you change the program. I hope it´s more clearer to you now what I´m thinking.Dome wrote:KITT was often reprogrammed, so it should be also possible with KARR-Jake wrote:That´s a very good question, KARR 2000. It´s hard to say why they couldn´t reprogram K.A.R.R. I think it can be because of the ancient computers (according to 21st century´s standards) they might have had in the F.L.A.G that you can add the programs in the unit but you can´t change the programs you previously made. I don´t know if the so called ancient computers had have that kind of problem in the real life but I suppose that might have been possible.
oh yes it is. It's sometimes not so easy for me to understand all the things wright, because English is just a foreign language for me. well you are Finish, so I think you can see my problemJake wrote:Good point, Dome! My thought was that can the programs already set in the K.I.T.T or K.A.R.R be changed. However, I had noticed that Bonnie or April had reprogrammed K.I.T.T but my question was that did they set some new program to K.I.T.T to replace the previous one or could they change the program that´s already there? I don´t know. I hope this following example will make my thoughts more understandable. Let´s say our example is the Surveillance Mode. As we know, Bonnie or other technician had set that program in the first place into K.I.T.T´s systems. Soon they develop the improved version of the Surveillance Mode. According to my theory, they remove the original Surveillance Mode program and replace it with the updated version. So in this case I just explained, according to my logic, they didn´t change the original program (didn´t reprogram). They just replaced the program with new one. I think the concept of reprogramming means that you change the program. I hope it´s more clearer to you now what I´m thinking.Dome wrote:KITT was often reprogrammed, so it should be also possible with KARR-Jake wrote:That´s a very good question, KARR 2000. It´s hard to say why they couldn´t reprogram K.A.R.R. I think it can be because of the ancient computers (according to 21st century´s standards) they might have had in the F.L.A.G that you can add the programs in the unit but you can´t change the programs you previously made. I don´t know if the so called ancient computers had have that kind of problem in the real life but I suppose that might have been possible.
I can see your problem very well, Dome. It´s surely harder to understand all things right in the first time if you´re operating with the language that´s foreign to you. Don´t worry, your English will improve. I´m sure of that. I´m not saying your English is bad, all I am saying is that it will improve. The discussion forums like this Knight Rider Online are good for learning languages. I think it´s a blessing to have the forums like these. Well, this was a little off-topic but I hope it´s all right.Dome wrote:oh yes it is. It's sometimes not so easy for me to understand all the things wright, because English is just a foreign language for me. well you are Finish, so I think you can see my problemJake wrote:Good point, Dome! My thought was that can the programs already set in the K.I.T.T or K.A.R.R be changed. However, I had noticed that Bonnie or April had reprogrammed K.I.T.T but my question was that did they set some new program to K.I.T.T to replace the previous one or could they change the program that´s already there? I don´t know. I hope this following example will make my thoughts more understandable. Let´s say our example is the Surveillance Mode. As we know, Bonnie or other technician had set that program in the first place into K.I.T.T´s systems. Soon they develop the improved version of the Surveillance Mode. According to my theory, they remove the original Surveillance Mode program and replace it with the updated version. So in this case I just explained, according to my logic, they didn´t change the original program (didn´t reprogram). They just replaced the program with new one. I think the concept of reprogramming means that you change the program. I hope it´s more clearer to you now what I´m thinking.Dome wrote: KITT was often reprogrammed, so it should be also possible with KARR-
- Dumbledore
- Michael Pajaro
- Advisor
In the strictest sense, Devon only THOUGHT Wilton had KITT dismantled. We don't know why that didn't happen. Wilton may have given the order and it just never got done because of the chaos going on in the Foundation at the time, or Wilton may have never ordered it in the first place.Dumbledore wrote:wilton knight ordered KARR to be dismanteled
Mike
It could be (and this is just a theory) that tension between Devon and Wilton Knight led to KARR's survival.
Bear with me here. We've heard several times that Wilton was the main impetus behind KARR's construction, (like from KARR's own voicebox for starters; "I was created by Wilton Knight...."). And yet in Trust Doesn't Rust Devon specifically said "I began work on a safer car" refering to KITT.
It could be that Wilton, after working so hard and putting so much blood sweat and tears into his prototype, had a hard time seeing how dangerous KARR was. Devon may well have tried to convince Wilton to have KARR completely dismantled, but all Wilton would agree to would be to have it deactivated and stored in the hopes that one day KARR could be repaired and meet his full potential (he may have even been less than honest with Devon about this, which would explain why Devon thought KARR was dismantled).
If all this were true, than Devon might have had to begin work on KITT without nessecarily having Wilton's complete support (at least not at first). At the very least Devon wouldn't have KARR to use for scrap parts or to reprogram.
Its a long shot, but its plausible.
Ghost
Ghost
- nivek
Ghost
hay sound good. I don't see any problem with it it sound reasonable to and it fit everything that they said in the show to.
Ghost
