Auto door buttons
- Rockatteer
Auto door buttons
Where are the Auto-door buttons located on Kitts dash?
- K.I.T.T
I think this is something like the spm buttons. But at a guess i would say centre console or roof.
K.I.T.T
K.I.T.T
Knight Rider Uk
http://www.knightrideruk.co.uk
- Knight2000
- Rockatteer
You've been looking at the pictures in Knight Replicas right?Acutally, no, they're on the lower console by the gear stick. There are also Up and Down toggle style buttons which are presumably for the windows.
If you look at the buttons on the show...they are not the same as the ones showen in any of the pictures at Knight replicas...
they have a white one in the middle marked "Auto door" then a green and red button on either side of it forminf a cross pattern...green is open, red is closed (I think) and of corse they replresent lef and right door.
- Rockatteer
a correction to my last post..
There is a picture of the buttons at http://www.knightreplicas.com/library/K ... -%20Knight%
but they still are not the same buttons as the ones on the center console. Checking the pics of the upper console shows they not there either...hmmmm
- Rockatteer
picture is at the bottom of the Knight Racer gallery at Knight Replicas
- Knight2000
- aussieknight
I reckon there's a phantom panel that contains those buttons, the auto window buttons, the surveillance mode control and display (check "Just My Bill"), the voice projection indicator, and the SPM/EBS buttons panel, etc. But hey, there's only so much room in a car, right? They had to go somewhere. I personally would have put them on the existing panel(s) behind the wheel.
"What do you mean, 'get'? You ARE in big trouble." -KITT, Not a Drop to Drink.
- Rockatteer
Ok well if you compare the picture on your video with a shot of the lower console, you'll see that they are not the same buttons.No. Actually I used my taped ep of the Pilot [amongst others]
- aussieknight
Actually, I just checked the knightreplicas pages and found a good pic of the console, and it seems to me that the four centre white buttons seem to be rocker switches too. Check this...
http://www.knightreplicas.com/library/K ... 1-0160.jpg
Or is it just the angle (?)
- aussieknight
OK. I dunno why it didn't work, but the link should.
- Rockatteer
not working for me.
- Rockatteer
Much BARRR HAAAARRRRR HAAARRRR in your direction!!
