Where are SPM and EBS buttons?
Knightline
Does anyone know exactly where the little door that slides open to reveal the buttons for SPM and EBS is? I have only recently seen several episodes of the fourth season, and haven't seen where Michael actually reaches to activate the switch(es), only closeups.
- Skav
ive said this before and ill say again: view KOTJ and then before michael chases the plane at the climax, he goes to press buttons on the roof...while his finger is pointing to the roof, he mentions that its a good time to go into SPM.
so my guess it is there!
Skav
Skav
- Skav
ive never seen him pointing his fingers in front of him in other eps? where was this?
Skav
Skav
Well, for example, in Many Happy Returns, we never see either of his hands go up above his head just before going into SPM the first time, he remains with his arms in front of him, as standard with holding on to the steering wheel. The second time in the same episode, he shifts his shoulder, not up, but leans forward just before going into SPM. And that is just in today's episode, it occurs in many others. When he reaches out to retrack the SPM and EBS, he takes his hand off the steering wheel, and moves it to the side.
- Skav
Then it's rather baffling why he'd aim for the ceiling in KOTJ. He could have easily made a mistake in knowing where the buttons were since it was a new feature and just quickly saw where the correct place was at the last minute....but the most likely reason is that it's another continuity error again.
Skav
Skav
It's not uncommon with Hasselhoff. There are a few episodes (I would have to look through the nitpick guide again, there are so many nits now to tell you which ones) where Hasselhoff presses the turbo boost button over his head, then later goes forward. Hasselhoff seemingly had a button fetish, and pressed where his urge guided him.
- KI Three Thousand
Assumption
Ok in KITT's more comman controlls like pursuit KITT or Michael Knight can activate hence Michael Knight doing it is optional. But Pursuit, Turbo boost is defenetly on the control pod hanging on the steering wheel. SPM and EBS was never finilized but the logicl spot for the control pod for both those functions would fit in the Roof but then KITT was a T-Top and convetible. The dash has far to many curves to fit that flat of a control consule. In the midile of the T-Tops I always assume is just back up controls for stuff like turbo boost, Pursuit ETC... Hence if the control pod over the steering wheel Michael Knight don't want to use He could use those insted makes sense to me.
- Scott Kirkessner
Re: Assumption
Actually.... yes, turbo boost is on the switchpod, but Pursuit is one of the 4 red buttons near the TV's
-Scott
-Scott
- KI Three Thousand
Actully where both right in that
Thanks for the riminder I can't beleve I for got that one. Auto Cruise, Pursuit, manul is under the two T.V.s in season one and under the single T.V. of the second dash I'm so
that I forgot that.
Knightline
- Joe Huth
My best guess is that the SPM/EBS buttons are located below the dash, in front of the gear shift. If you're familiar with the stock Trans Am, I would say the buttons were located where the radio is. Hasselhoff mainly reached for that area to activate SPM, although sometimes he pressed some overhead buttons, but I think he was activating/deactivating something else in preparation for SPM.
- jup
- Location: SD, CA. USA | Web site: http://www.jupircbot.8m.com (jup's KR game project 'ghosts' here)
I think it would be interesting to see one of the actual original episode scripts to see if it always denotes to reach for a specific button or just says something like, "(Reach for button on dash.)"
Also makes me wonder if David actually tried to read what each button was marked as. (Because, I'm pretty sure that the "complete" field car had a functioning and buttom marked dash. But, I'm not sure about most of the other "KITT's" even having prop dashes.
