Do you want to have KITT as your assistant? So, this is the way...
http://youtu.be/PK0Wa9TwtyM" onclick="window.open(this.href);return false;
Know more about guile3d Virtual Assistant accessing links below.
https://guile3d.com/en/product/" onclick="window.open(this.href);return false;
https://guile3d.com/en/guile-3d/" onclick="window.open(this.href);return false;
KITT is one of several available skins...
KITT - Virtual Assistant
- knightbrazil
- knightbrazil
- knightbrazil
Re: KITT - Virtual Assistant
See Virtual KITT Assistant in action...
https://www.facebook.com/video/embed?vi ... 7328316648" onclick="window.open(this.href);return false;
I use the Ultrahal AI in my KI3T. The speech recognition could be better (especially while driving as there is so much background noise), so I don't use him as much as I'd like. He learns better from typing on a keyboard, but that's not really practical or safe while going down the road.
Ultrahal can be found at: http://www.zabaware.com/" onclick="window.open(this.href);return false;
- knightbrazil
2knight is there KITT's voicebox avatar in Ultrahal AI?
I've looked before and haven't found a voicebox avatar for Ultrahal. It's always possible someone has created one since. It probably wouldn't be that hard to create, but I've never had the time to try to figure it out.
They do have a plugin for a "Knight Rider brain." I've not tried it since I've been more intent on working with a blank slate and teaching my own what I want it to know. The brain plug-in can be found at: http://www.zabaware.com/files/type.asp?iType=12" onclick="window.open(this.href);return false;
Another program that might be useful for some people is E-speaking. http://www.e-speaking.com/" onclick="window.open(this.href);return false; You can use this to give the computer commands. I usually use it to pull up Knight Rider animations, but it could probably be put to more advanced use. I suspect that someone really tech savvy could use the program with some additional hardware to actually have KITT unlock doors and pop the trunk.
