Excellent Condition, almost new!! - $50
Cross-Fire Intake from a Corvette, if you gfuys wanna use this instead of the stock Cross-Fire - $50
Barely Used New Fuel Injectors for your Cross-Fire, originall $100 each, and hard to find. - $150
T-Tops from my 1983 Trans Am. The plastic on the outside is faded as usual. Just needs some Black trim paint. The passenger side plastic has a small crack as you can see from the picture. I can sell them for $50, these usually sell over $100, the box is 34x18x18 at 40 pounds, I calculated shipping will be around $60.
Brand New Front Fender Side Marker Lamps $25
Trunk Release Solenoid $50
Headlight Relay Module $30
Doeskin Mix Seatbelt Lot $150
As you see in the pictures: 4 back male seat belts, 1 female seat belt. 2 front female seat belts, one of them is kinda cracked open. 4 front male seatbelts, the 2 middle are in excellent condition, but don't have the top belt connected to it, they stand alone. the 2 other kinda worn out and have the top belts connected, you can always remove and put to the 2 good middle belts!
2000 Trans Am, Chrome 16" wheels. Selling for $400 These always sell for more on ebay!
1989 Original GTA Trans Am Wheels, one wheel the lip of it is broken off, selling for only $350 plus the tires. For $300 you usually buy 2 GTA Wheels. Tires have around 70% tire thread, so you can have fun with them spinnig/burning!
Brand New Rebuilt Front and Rear Brake calipers plus Bendix Brakes $200
First come First serve!!
