Turbo Boost
Turbo Boost
This is how turbo boost should be,its from larsons other great show the fall guy,man those jumps looked cool
http://www.youtube.com/watch?v=yAIDqyi2 ... re=related" onclick="window.open(this.href);return false;
Re: Turbo Boost
I liked the one where the truck went through the panes of glass. What was that show about?
Re: Turbo Boost
Well to be honest I have no problem with the trubo boost except that it looks like is ejecting plasma to "jump" and plasma is basically super hot ionized gas and that would most likely end up killing anyone nearby KITT, a pneumatic system (air) sounds like a safer bet than a plasma one, just my opinion anyway. I love the show but I hope that that thing the boost ejects is not plasma though it looks eerily like it...
Re: Turbo Boost
I only dislike the fact that entire conversations are taking place while the car is in the air
I don't get that
The car appears more like it is flying than jumping when people are talking so long. Other than that it's not bad.......
Re: Turbo Boost
Turbo Boost b4 either KR or FG: the Dukes & the General Lee(DUH).
Re: Turbo Boost
i have to agree with Knight94 i think the dukes was the first show to do that. unless starsky and hutch did it which idk cuz ive only seen the first 2 seasons and so far, no jumps. but that vid looked like a cross between dukes of hazzard and knight rider. i really like the truck tho.
actually i just realized somethin, dukes was not the first to do that, aren't we forgetting about the Bandit! i'm sure the dukes was the first tv show but i'm pretty sure the bandit was the first to do a jump like that "turbo boost" so to speak
- Rockatteer
Re: Turbo Boost
actually the one thing I didn't like about TOS turbo boosts was that quite often the car went nose down and you could see that it was gonna smash on impact. If they can smooth that out with CGI so the car jumps in a smooth arc it'll look better.
I think Dukes actually had weights in the back of the car to stop it from going nose down while jumping.. could never work out why KR didn't think to do that.
Re: Turbo Boost
Actually even thoug thety made the car jump it never jumped that far or that high in reality, check out Mythbusters they debunked this by repeating the same stunt to see if was possible and the car ended smashing itself when it reached the other end, you would not only need a sistem that catapults you into the air but also allows for a smooth and safe landing...Rockatteer wrote:actually the one thing I didn't like about TOS turbo boosts was that quite often the car went nose down and you could see that it was gonna smash on impact. If they can smooth that out with CGI so the car jumps in a smooth arc it'll look better.
Re: Turbo Boost
Dukes of Hazzard broke several car jump records, and re-set their own.
- Rockatteer
Re: Turbo Boost
It's a well known fact that KR jump and smashed a lot of cars in KR. Thats why they used so many stunt cars.PunkMaister wrote:Actually even thoug thety made the car jump it never jumped that far or that high in reality, check out Mythbusters they debunked this by repeating the same stunt to see if was possible and the car ended smashing itself when it reached the other end, you would not only need a sistem that catapults you into the air but also allows for a smooth and safe landing...Rockatteer wrote:actually the one thing I didn't like about TOS turbo boosts was that quite often the car went nose down and you could see that it was gonna smash on impact. If they can smooth that out with CGI so the car jumps in a smooth arc it'll look better.
Heres a youtube video clip which shows some of the landings.. ouch!
- PHOENIXZERO
Re: Turbo Boost
Mythbusters has the habit of doing somethings half assed and sometimes no assed at all, the biggest issue I have with the show is that they go into pretty much everything with the preconceived notion that they're going to bust the myth and end up leaving out several factors in their quest to bust it that might make the myth true. Hell, look at the episode where they ran a car up a ramp onto the back of a semi. They were actually surprised that it worked even though it was clearly done in Knight Rider with no "magic" aside from the expanding insides of the trailer to the set, heh. They certainly did jump the cars (before going to the models) a lot and many times that car certainly did go quite high in the air, which as Rockatteer pointed out, resulted in a lot of smashed cars, specifically the bodies since they did also use different chassis.
There's a good reason why the stunt driver(s) who did the turbo boost stunts f'd up their backs as the result of all the jumps and it wasn't from doing illusions.
The new and again improved evil's advertisement is currently too long and too badass to display here. But let's just say that with now 50% more evil, this **** is great!
- weeezl
Re: Turbo Boost
PHOENIXZERO wrote: There's a good reason why the stunt driver(s) who did the turbo boost stunts f'd up their backs as the result of all the jumps and it wasn't from doing illusions.
- PHOENIXZERO
Re: Turbo Boost
Man, I should have reworded that a bit when I went back and edited my post to add a bit more to it. I think "as the result of all the jumps " could be removed, hmm... I think I'll still try to do it.
Then again, nevermind... I don't care.
- Stuntman Lee
Re: Turbo Boost
From watching part 3 of the George Barris video, i dont see why they cant do proper jumps in the new Knight Rider.
As shown in the photos, make up a space from, put a fibreglass/rubber shell over it and as its the 21st century, instead of damaging stuntmens backs, they can use remote control to drive it.
Gotta be easier than pissing about with cgi surely? Even if they did it properly 5 times during the whole season it would be worth it. And appreciated!
Love child of The Hoff.
- HyperCaz
Re: Turbo Boost
Or if they do it properly 2-3 times and film it - they can repeat those clips over and over, like in the good old days...
BEWARE: shipper alert
- weeezl
Re: Turbo Boost
I think we should worry more about the show getting re-commissioned for a second season for now.
They may well just get a bigger budget and can afford to make some stunt cars.
Re: Turbo Boost
At least let them make the 17 episodes they've been asked for first, then hopefully we can get to 22 and beyond....weeezl wrote:I think we should worry more about the show getting re-commissioned for a second season for now.
I'm looking forward to Ki3t becoming the 2009/10 shape mustang as the series progresses
- Rockatteer
Re: Turbo Boost
Actually it's just occurred to me that the Mythbusters where probably looking to see if it was in fact possible for a car to jump without being smashed.. in other words if what we saw on the screen could happen in real life.PHOENIXZERO wrote:Mythbusters has the habit of doing somethings half assed and sometimes no assed at all, the biggest issue I have with the show is that they go into pretty much everything with the preconceived notion that they're going to bust the myth and end up leaving out several factors in their quest to bust it that might make the myth true. Hell, look at the episode where they ran a car up a ramp onto the back of a semi. They were actually surprised that it worked even though it was clearly done in Knight Rider with no "magic" aside from the expanding insides of the trailer to the set, heh. They certainly did jump the cars (before going to the models) a lot and many times that car certainly did go quite high in the air, which as Rockatteer pointed out, resulted in a lot of smashed cars, specifically the bodies since they did also use different chassis.
Not if the cars where jumped while making the show.
