Does anyone have a wiring schematic to make a simple KITT/KARR scanner using LEDs?
I've always wanted to make one (just to show off, of course), and I've heard that it can be done with just a battery, some LEDs, and 2 capacitors, but I've never even seen one before in person, nor have I even tried to build one.
scanner schematic question
- walter h. anderson
Starship
When Knight Rider first aired and I wanted to make a scanner for my car, I came up with an idea: A motor spinning a contact that would touch a sequence of contacts in a circle. I only used seven lights, and if you number the lights, I had 12 contacts in the circle, numbered 1-2-3-4-5-6-7-6-5-4-3-2. That way, as the main central contact was spun by the motor, it would illuminate those lights in the back and forth sequence, over and over again.
Of course, I had problems with the contacts sticking or wearing out, so I eventually changed it to a motor slowly spinning a magnet around a circle of magnetic reed switches, with the reed switches going to the lights in the same sequence.
Now, I just use an electronic scanner that I ordered from the JC Whitney catalog. I've thought about adding diodes and capacitors to that scanner to get a better trailing effect as the light moves, but I haven't tried that yet.
I try to put a little KITT in any car I own!
