I agree, and I also believe that the SPM was used to get to a certain place within a certain timelimit. If you would take some time looking at the previous series, you will notice that they never had a problem getting to a place in time. But now all of a sudden they need something that increases the speed with 40% in order to get to that specific place on time.but they always seemed to get there just in time, as in the previous serieses.
if memory serve orretly were there not a couple of episodes where kitt was destroyed e.g. junkyard dog, where im assuming the sanner was destroyed, or damaged in an extensive way, and in knightrider 200 the movie was kit not setup in michaels ar without his scanner (not sure on this) and in another episode wasnt kitt built into a tv set or something when the knight 200 got stolen? i think this is another ontinuity error, but im sure its if kitts main box gets destropyed then its fatal. so theorhetialy kitt may be able to survive the impending rash michael would i agree be inevitbly killedHungarianKnight wrote:I like SPM but I think that Turbo Boost is impossible in this mode. Even if Kitt could gather thrust to break free from the downforce of the extended car body parts, the landing would be fatal. The extended nose would simply break off and that would mean that the front scanner'd get damaged. We all know from TDR that the destruction of the scanner is fatal to Karr and Kitt so Kitt would probably die at this manouver. Not to mention his passangers...
Any idea of Turbo Boosting in C-Mode?
