![Image](http://memimage.cardomain.net/member_images/2/web/602000-602999/602788_25_full.jpg)
![Image](http://memimage.cardomain.net/member_images/2/web/602000-602999/602788_26_full.jpg)
thanks for the compliment on the lenses. i've been searching around the net and found a few clear lens leds but it apperars that they might light up amber. the yellow ones i used looked pure yellow when they were lit but appear to look more amber than yellow behind the clear lens for the scanner once the car was put back together. i guess it is going to be trial and error to get the correct color. does anyone have a good pic of KARR's scanner to compare? i have "KITT vs KARR" that i downloaded from the net but the quality isn't too good so it actually makes it look like KARR's scanner is redHondaSiR wrote:
pewter 02ws6: Those replacement lenses sure look great! They appear to have been factory made. And the yellow LEDS do make a difference when converting KITT into KARR. Good luck in your search for better transparent yellow LEDS (and also in painting KARR's silver tone).
that is actually pretty neatCB2001 wrote:Though I know everyone is psyched to have the 1/18 scale KITT out, I've found a 1/24 scale KITT paper model here: http://www.geocities.jp/mamecraft/knight2000_g.html
Figured I'd post about my find.
first off.... welcome aboard!Tetsu wrote:Hi guys,
I'm new to this forum but have been lurking for a bit.
Pewter 02ws6, very nice customization with the yellow LED's! How did you do it if I may ask? Was it easy to replace the red LED's with the yellow?
Tetsu
I was broke before Christmas. LOL Now Im rich! *evil chuckles*HondaSiR wrote:And I thought you were broke.TurbomanKnight wrote:And I'm looking forward for some pics of your project. If It does work I'll give you $100 for it. Think About it. LAter Man
Okay, that's the hottest thing I have ever seen.CB2001 wrote:Though I know everyone is psyched to have the 1/18 scale KITT out, I've found a 1/24 scale KITT paper model here: http://www.geocities.jp/mamecraft/knight2000_g.html
tetsu, the soldering gun i used was only $5 at radio shack and is sufficient for what you plan to do.i don't know of the one you plan to buy but if it is as cheap then it won't matter.Tetsu wrote:Hey there pewter02ws6,
Thanks so much for your detailed explanation. It will help me a great deal. I never soldered anything before but I was looking at ebay for a soldering gun and came across the same one I saw on T.V. The cold/heat soldering tool. Is that okay for a job like this? I mean it's failr cheap and I figured I'd be using the tool quite a bit anyways. But what do ya think?
Also check out this website, http://www.knightlight.co.uk/pr-ks5008.htm
I was going to buy the red scanner for my 1:18 car but I'm not sure if it's compatible spacewise. Here's my plan. I remove the old 5 LED scanner system, remove the thin plastic in front of the engine to give me a little more room, install the U.K. 8 LED scanner system, and solder the postive & negative wires to the already existing battery compartment. Not sure If my plan will work, but I shall post pics and let you guys know.
Also, before I forget, is it possible for me to correct the "pausing" effect of the 5 LED scanner system? U know what I'm talking about?
Thanks again boss,
Tetsu
That's a nice find CB2001! I've never seen KITT as a paper model before, its nice to know it somehow exists. But I wouldn't trade any of my diecast or plastic model kits for one though lolz.neps wrote:Okay, that's the hottest thing I have ever seen.CB2001 wrote:Though I know everyone is psyched to have the 1/18 scale KITT out, I've found a 1/24 scale KITT paper model here: http://www.geocities.jp/mamecraft/knight2000_g.html
