For Questions Regarding KRC Video/Trailer
Victor Kros
Post by Victor Kros » Mon Aug 25, 2008 8:07 am
Greetings,
I've created this thread not as an excuse to gather more praise for my work, but to answer some questions that you might have specifically related to how I created or came up with the announcement video for The Knight Rider Companion. I've received some PMs and emails from people asking questions about it, so I've decided that if anyone wishes to ask me something, this thread is the best way to address it on a more global level.
Please keep things respectful and I will do the same. You can pretty much ask me anything you like as long as it stays on topic. I will cover more specifics about the book itself in another thread later in the week.
If you need so see the video again, I have reposted the link to it for your convienence
http://www.youtube.com/watch?v=WqUxYVU74RE&fmt=6
Thank you.
=VK=
:dash:
Re: For Questions Regarding KRC Video/Trailer
Post by neps » Mon Aug 25, 2008 8:37 am
Perhaps you can answer those questions you've already heard? That way we aren't repeating what you've already answered, and it helps the people reading this to get something out of the story/thread before hand.
Victor Kros
Post by Victor Kros » Mon Aug 25, 2008 8:09 pm
Ok fair enough.
1. How did you do the scanner effect with the text? (I think Sue asked me this in another thread).
To do this particular effect, I started with a scanner graphic I made back in September for Glen's Knightcon video, you can also see it in my earlier banner animations and in the title of that particular video. Having moving footage that was both bright and colorful against a black background, I was able to use that movie file as essentially a lightsource for another image beneath it. Using the scanner movie as my light source, I put another graphic of the KITT car I did for the Saugus poster art over the top of the scanner movie and set it to a layer mode called "overlay" which is common in Adobe programs such as Photoshop or After Effects.
Here's a visual example of how this works.
- The original scanner movie file
- My original K.I.T.T. art.
- The K.I.T.T. art placed over the scanner movie file in "overlay"
Now imagine this effect animated and you get a good idea how this works. Quite simple if you know how to do it.
Then I added in the text on another layer in After Effects and created an animated mask to obscure the letters in rhythm with the scanner sweep so that when it sweeps to the left, no text shows and when it sweeps to the right the letters are revealed.
Here's an example of what that looks like from a still of the video
That's how it's done.
2. What program did you use to make the video? I used After Effects and Photoshop for the graphics and animation. I used Adobe Premiere to render out the final project.
3. Why didn't you use the Knight Rider Theme? I didn't use the Knight Rider Theme because my video deals with mostly still imagery and I couldn't get the timing to work out. If it was just still images of the book, it would have been no problem but I had titles to address and so on.
I wanted music that had a very movie trailer like feeling to it. I decided the best way to make things work was to make Knight Rider references (sound clips) blend with the music I selected to use. This then makes the music gel with my subject matter. I did want to use some form of visual and audial nod to the original Knight Rider series, so I used the ending music (Don Peake) instead and an ending desert shot as my final imagery. I also made sure to give every musician their proper credit for using their wonderful music.
4. Why is the video fast in some places and slow in others? Due to the high amount of memory I needed to render the different parts of the video, I was forced due to "out of memory" errors to render out each section of the video in parts then render the final video out of Adobe Premiere. Apparently After Effects will only utilize 2GB of RAM and Windows Vista has not yet figured out how to increase it to access more then that, that I could find. I checked the net for suggestions on how to do this but none of the "tricks" worked for me.
Because I did most of my sound syncing in Premiere, I basically had to make the sound fit the clips I was using. This required me to speed up some sections of video and slow down others to keep my timing within the music track and where it blends into the ending theme music.
I think all in all though, the video flows pretty well. There's always room for improvement but in this case it gets the message out I'm trying to convey and it gives a sense of excitement that's both a visual and audial experience. I posted both a quicktime and the youtube (originally) so people have the ability to pause or scrub through the video to see what might capture their attention that may move too quickly for them to really see. Likewise with the end credit info.
If anyone else has any more questions, feel free to ask.
=VK=
:dash:
Post by weeezl » Mon Aug 25, 2008 8:59 pm
victor kros wrote:4. Why is the video fast in some places and slow in others? Due to the high amount of memory I needed to render the different parts of the video, I was forced due to "out of memory" errors to render out each section of the video in parts then render the final video out of Adobe Premiere. Apparently After Effects will only utilize 2GB of RAM and Windows Vista has not yet figured out how to increase it to access more then that, that I could find. I checked the net for suggestions on how to do this but none of the "tricks" worked for me.
Its works much better on XP( its able to address 3gb, i dont use after affects personally but its pretty much common place with adobe products) due to Vista being extremely resource hungry and bad coding on Microsofts part, that out of memory error crops up more than anyone would like. Short of changing to a 64bit OS which also comes with a whole host of its own problems, bad driver support, programs code not updated to utilise it etc....I guess this is what we have to put up with until Windows 7.
Most of the tricks to get a 32bit Os to utilise more memory just dont work (as you know), they fool the memory register to address the memory but as im sure you also know can only register 4gb maximum and then factor in the memory on the graphics card also.....theres a big chunk of it gone too.
Vista SP1 32bit see`s 4gb in the system but doesnt use it, ive got 4x1gb sticks in mine and a 512mb 9800GTX GFX card, i think the most used is 3gb give or take...
Not good enough in my opinion and 64bit versions have not matured enough to really warrant use yet.
I never had any problems like that until I "upgraded to Vista" :D now wheres that XP disc gone again????
Just in case you might find it interesting, on my other machine ive got Vista dual booted with XP which is what most of my productivity software is on, it helps, not so many memory errors..
Victor Kros
Post by Victor Kros » Mon Aug 25, 2008 10:00 pm
I never had any problems either, this is one reason I hate dramatic change. When the world forces you to accept something new that you're just not ready to have to re-learn or adapt to. Good to know I'm not the only one who feels this way about Vista.
=VK=
:dash:
Post by weeezl » Mon Aug 25, 2008 10:20 pm
victor kros wrote:I never had any problems either, this is one reason I hate dramatic change. When the world forces you to accept something new that you're just not ready to have to re-learn or adapt to. Good to know I'm not the only one who feels this way about Vista.
=VK=
:dash:
ooh mate, thats a funny subject lol, most of the big companies selling new machines even started offering XP downgrade discs for their supposed upgraded operating system! even Dell lol. work that one out! :D
Post by Michael Pajaro » Tue Aug 26, 2008 12:27 am
Mac OS X Leopard, ftw.
Post by FuzzieDice » Tue Aug 26, 2008 12:51 am
I have two XP Machines, a Vista Machine and an old Win2kPro machine. The Vista laptop I can do most things, including the podcasts, audio, MIDI, software development, watch DVDs, etc. I haven't done much video at all with it though. I have done stuff on the XP machine instead. Super Video Converter will NOT run on XP no matter how I tweak settings. So that's a downside. So I guess video stuff is best on XP. I've heard that a few times online on how XP is better at some high performance stuff like video and audio.
They *are* phasing out XP now though. In fact it's not available in stores. I hope my XP copies won't be unusable after EOL and I end up having to reinstall something else. :( I think I'd switch those machines over to Linux. I know the hardware in those machines won't handle Vista.
Post by Sue » Tue Aug 26, 2008 2:59 am
Ah thanks, It’s nice to hear someone else is using a PC and Premiere! I really do envy all my friends that have final cut and a Mac. -Oh okay so you were using After Effects, I really do need to go out and buy that one. I’ve been using image ready to make little movies from stills, but I think I could do a lot more if I had After Effects. Now I don’t know a thing about computers, but I know that in premiere you can add to the virtual memory, that helped me out a bit, maybe After Effects has something like that.
I hear you on the Windows OS, my brother works for Microsoft and yet I have no desire to install Vista, not only that I wish I had never installed service pack two!
msKEN
Post by msKEN » Tue Aug 26, 2008 6:45 am
Michael Pajaro wrote:Mac OS X Leopard, ftw.
You know, a year ago I would have said you were crazy but I really do like this OS. Apple finally did something useful. :good:
Post by weeezl » Tue Aug 26, 2008 10:42 am
I heard good things about Macs OS, personally I`ve never used it though.
Being as new Macs are based on Intel Core hardware, there is a way to install it on PC`s, I think I might use my backup Core 2 machine as a test bed and give it a whirl for myself.
I would`nt worry too much about that, I know people still using Windows 98, Given the huge XP user base, hardware manafactures will still provide driver support and I know new software will be compatible, just no more official updates and service packs.
Sue wrote: I hear you on the Windows OS, my brother works for Microsoft and yet I have no desire to install Vista, not only that I wish I had never installed service pack two!
Have you thought about service pack 3, its a whole bunch more stable and actually makes XP faster? Ive had no problems with it at all, havent seen the BSOD in a while.
But as for my Vista machine....................... :evil:
